I struggled with this forever on Mac. Once I made the “installation” change in Font Book, fonts rendered correctly in Bambu Studio. Thanks Dylo!
How did you do this: “installation” change
I followed @JJTechPrints instructions above and still not working for me. I see the font in BS, but its just generic. I put the font file in both libray folders on my mac
Here’s my overpass font test file. If you followed my steps above, I’d suggest making sure you closed all instances of Bambu Studio, and perhaps restart your computer for good measure.
overpass-font-test.3mf (258.6 KB)
If you open FontBook and go to settings (⌘,) you’ll see an “Installation” menu. Change the default install location to “All Users”.
After I did that, I removed the fonts I had previously installed for use in Bambu Studio (deleted in FontBook). I then opened the fonts I wanted to add to Bambu Studio in FontBook, which installs the fonts on the Mac. I restarted Bambu Studio and they functioned as expected!
The good thing about this method is that the “Installation” change affects Font installation for anything you add in the future. Meaning, once you make this change you’ll never have to worry about it again (and fonts will behave correctly in Bambu Studio)!!!
Thank you so much! This worked perfectly. ![]()
This! I had already done everything else but didn’t see the “install for all users” then your post made me look again and it was under “show more options”. Restarted and its working! Thank you!
99Stagea, not only does this work on MS 11, but I tried it with one font to be sure I fully understood and the font is there while I am working in BL Studio, without restarting. I will restart, but this is great. You are awesome, thanks for sharing knowledge that doesn’t lead us in circles and down rabbit holes. This is perfect for me!!
For those using Linux I just figured it out, you need to put any custom fonts you want to use in ~/.fonts/ and run fc-cache to refresh the font cache. Then you can re-open Bambu Studio and the font should be there. This works even with the Flatpak version.
What you have to do is to dowland a .ttf archive, then open it and finally, click on install, automatically Bambu Lab will detect it and it sopuse to appear there, I tried it and it worked very good.
This worked 100 percent! You can honestly get and font zip and duplicate this and it should work just fine!
My process of adding fonts is bit different. First I use Unicode site convert normal text into the different variation of the fonts. From where i pick up the one that looks suitable, then i try to find it in the Bambu studio. Here is the site i’m using. ecriturespecial. fr
Thanks Guy! This was it for me, I didn’t even have to restart Bambu.
