Would like to request a feature to add notes within Bambu Studio within each build plate. I often find the need track notes within my projects and sometimes specific to each build plate (e.g. reminders of settings that worked, didn’t work, post processing notes etc). Maybe this could be like another tab on the build plate view. Would also like to be able to show/hide them.
I have my first printer P1S combo for 4 weeks now. If it bothers me enough then I might just make the field bigger myself and compile my own Bambu Studio.
I am new, I tried searching the forum for “notes” … and got too any results, then no results and almost gave up. Then I went to the specific “software” category and tried some of the filter settings next to search and found this thread- maybe that will help someone else. Thank you!!
Right click somewhere on the screen and select “Add Primitive”
Select “Cube”
3)With the newly created cube selected go to “Scale”, make sure “uniform scale” is not selected and flatten the cube into a flat surface as well as adjust the size as needed.
Use the “Text Shape” tool to add text on top of the surface.
The benefit here as you can see from the example image is that you can add specific notes that are highly visible right there with your model as needed.
It would be much better to have a dedicated notes tool that allowed for notation within the build plate area but this is the next best thing!
