Hi,
i was wondering if it is a good idea to add a rubber layer 1,5cm under the A1 to reduce a bit more the vibrations.
What do you think ?
Hi,
What do you think ?
Hi Kabal,
You may find this thread interesting.
For best effect, add weight directly underneath your printer before putting that on a springy foam.
I also made a little, playfull experiment/tutorial here Anti-Vibration Pad Mk I by EnoTheThracian - MakerWorld. Tried it on my X1C to good effect. It is going a bit over the top though
. Should work with a lighter printer too although you may need to strap your printer to the weight.
Hope this helps,
Eno
Mine makes noise too not sure if it’s the bed or adjustment
