Adding Text to the Bottom of a Part in Bambu Studio
Something is corrupted on that keychain STL file, you need to redo it. Perhaps run the keychain through STL fix, then try adding the text again:
https://www.formware.co/onlinestlrepair
I repaired the STL and now it is working. I think that is the official answer.
If a part being sliced in Bambu has text added to the bottom of the part in contact with the print plate directly in the Bambu slicer, you can use a projection of 0.05 mm and a depth of 2 mm. It shoudl work and print flush.
If it is not working, and the added text dissapears when you slice the part, you need to repair the STL file to remove corruptions, then open the repaired STL again in Bambu to get the tect to work.
STL files can be repaired using this link: Free online stl repair tool
Thanks for the advice @maxim3D
I’m using version 2.4.0.7.0 and adding text to the bottom of a model is still a nightmare, if it works at all. The workarounds posted in this thread are not available (for example, no option for “Modifier → Always Flush”).
STL Repair site is not able to handle the file, either.
A Modifier is always flush with the object it is applied to. Even if it isn’t. It only needs to penetrate beyond its host objects surface.
The modification is only applied to the combined volume and the modifier does not lift the part from the build plate. So any modifier exceeding the surface of the host object will always leave a flush modification.
But, yes, text in Studio is rather cumbersome.
I am newer to 3D printing and I have been trying to work through this issue as well. So far I have found that I can simply add text to the bottom of an object originated from Bambu Slicer, like a block and it will print. When I try and add text to the bottom of an Object file (obj) exported from TinkerCad, it does not print. When I export that same project as an STL file, then add the text to the bottom of the object, it does print.
I am adding the text in Bambu Slicer because I have more font options compared to TinkerCad. There may be a better way to do this but as I mentioned, I am newer to 3D printing and TinkerCad is the first application I have used to created prints.
what do you mean by always flush? what does this refer to?
A common way to print text on a part is to place it on the build plate. This gives it clean, crisp borders.
However, if that text is of “Part” type it’ll portrude from the surface, lofting the remainder of the model, making it unprintable without supports.
So people often try to ensure that the text is at exactly the same level as the surrounding surface. If two surfaces are exatly parallel, they are “flush”.
Changing the text type to “Modifier” ensures flush surfaces as the resulting print will always only consider the original models geometry, applying only modified settings (for example filament type) to the intersecting volume.
oh i thought they were referring to flushing, as in what happens to leftover filament after printer changes color haha
