Additional fan noise from rear of X2D Combo during printing
I’ve got a weird issue with my new X2D that I seem to be alone in experiencing, as I haven’t been able to find a single post describing the same problem. There seems to be an additional fan somewhere in the back of the printer that spins up as soon as a print starts and produces a fairly noticeable grinding/buzzing noise. This one fan alone makes the printer significantly louder than any FDM printer I’ve owned so far. It’s actually loud enough that I’m starting to consider moving the printer out of my office, which would be a shame since I have a dedicated spot for it on a rock-solid marble slab that’s pretty much the perfect size for the machine.
I’ve tried tracking down which fan it is by going through all available fan controls in the printer settings and lowering or disabling them one by one, but no luck. Whatever is making this noise seems to be built into the machine and not directly controllable through software. I’ve also rewatched a bunch of X2D reviews to see whether anyone mentioned this particular noise, but so far I haven’t found anything.
I’d really like to identify the component responsible, either to see whether it’s something I can fix myself or, more realistically, whether it’s a case for Bambu Lab support to replace the part. This is probably a separate issue, but I’ve also noticed that the aux fans seem to ramp up much more aggressively than they did on my old P2S. Maybe that’s normal behavior on the X2D, but it definitely caught me by surprise. I’d be curious to hear whether other X2D owners have noticed the same thing.
Any ideas would be appreciated!
P.S.: I’ll try to get a recording of it after work and add it to the post.
I have a dud of an X2D, it’s been operational for maybe 2 weeks of the 5 weeks I’ve owned it. Going from a P2S to the X2D has been a surprising step down in print quality. I hate it. It’s the worst printer I’ve owned in 11 years of 3D printing. I’ve had to disassemble the whole back panel/buffer/extruder/poop chute 5 times now.
One of the issues seems to be a fans that run at 100% when the machine is switched on.
This includes the two hotend fans either side of the toolhead and the MC board fan which is at the rear of the machine. (See photo).
So it might be the MC board fan then? Gotta check this one out and then report to BBL support. Appreciated!
Are there any errors on the UI?
Nope, I wish. This drives me nuts.
Oh, so this might be the MC board fan - because the noise comes from there. The fan runs a pretty long time after the print itself finished, so that’ would make sense.
If you set the machine in silent mode do you hear the same noise?
Yep. As it turned out, it was the MC Board’s fan. Bambu Support is on it, will most likely send me a replacement fan.
I also received an X2D and out of the box there is one fan that makes a particularly intense sound and it cant be controlled from the menu, is there after a print and during startup. It might not be as loud as the part fan on 100% but it is always there and makes the printer annoying to have in the office room.
@TiSo_Designs Curious to hear if you replaced the fan and that solved your issue? And if so how loud is the mc board fan when it is working properly, still very present or softer than the other fans at say 50%?
Actually, it turned out to be the auxiliary hotend fan. Its cable wasn’t connected properly. I’d suggest locating the noisy fan first and then checking whether its cable is properly connected. :crossed_fingers:
