Adjusting nozzle temps and flow rate
Hey everyone I was just thinking today, assuming i have fine tuned my x1c and i am getting good quality prints at 255celcius nozzle temps, lets say i want to increase my nozzle temps, i should decrease the flow rate to keep my print quality good?
I guess my question is, if you’ve getting good quality prints why do you want to increase your nozzle temp?
Ideally you would print a temp tower to dial in the optimal nozzle temperature and then print the flow calibration and pressure advance prints to dial in the filament at that temperature.
But once i set the pressure advance and flow rate should i go back and print the temperature tower again? so that i may check the temps with the new calibrated settings?
Ok i was confused, you are calibrating according to that temperature, so if i want to change the temperature then i will have to recalibrate according to that temperature
The reason im asking is because i am getting some filament to stick on the nozzle, therefore i wanted to play around with nozzle temperature and flow rate to maybe overcome this issue
