Hi all, I would like to print some threads on a model and have been told slowing down the print speed in this section may improve quality but I cannot seem to find how to do this in the slicer.!!! Can anyone help? Thanks
Here goes
- Right click on the part and add modifier - cube (or whatever shape you need). It will switch to per object settings.
- size and move the cube into position.
- select the cube you just added in the object list and adjust the speed settings.
Thanks for that, any idea how I move the modifier up to the area which is in the last 10mm of the print height ?? cheers
Another way that might be easier is to select the object, right click and add height modifier. Then you can change settings for that height range.
Thanks I have it sorted now. ![]()
