Aftermarket replacement parts as upgrades?
Hi everybody,
I was wondering if any of you tried some of the “aftermarket” upgrades available on AliExpress like these for example:
https://www.aliexpress.com/item/1005007593370397.html
https://www.aliexpress.com/item/1005007130938364.html
https://www.aliexpress.com/item/1005007535271194.html
https://www.aliexpress.com/item/1005006831339773.html
I’m not talking about simple build plates or the only one endorsed by Bambu Lab, the E3D Hight flow nozzle.
I’m interested in the last example as I recently had some issues that might have been caused by those parts. Also they should help with TPU.
Cheers !
I have had the FYSTEC for a bit on my P1S. Works as stock. The BTT will be exactly the same.
The lights will be fine as well. They’re just shorter with a power switch.
The handle can be printed, but if you want metal that would be ok as well. I thought about that one for my daughters mini but just printed one.
The only one of those four that I have purchased is the LED lights. I found that the lamp didn’t illuminate enough when the room was dark if I wanted to check a print in progress. The LED light strip is really bright, I wish it had a dimmer because it washes the camera out sometimes.
Links dont work cant find item.
at first it shows photo then sorry item not found?
The links work for me but they are all of them made by Fysetc.
Here’s a search with Bambu Lab: https://www.fysetc.com/search?q=bambu+lab&options[prefix]=last&type=product
