If you’ve ever used PowerPoint or a drawing program, you’ve probably encountered the ability to select a group of objects and align them either to the left, right, middle, top, or bottom edges.
I don’t mean to imply that this software should replace CAD, but I think it could benefit from expanding the existing “center object” feature to enable alignments based on the positions of multiple objects relative to each other.
Here’s the scenario: Imagine I have two objects that I want to align together to create an assembly or Boolean object. Currently, I have to do this manually or attempt to center the objects, which restricts me to concentric alignment where all edges are equidistant.
Here’s how it might work.
Plate is put into top-down mode(CTRL-1)
two or more objects are selected using the shift-mousedrag or CTRL-Mousclick
Right-click on any of the objects and provide a drop-down menu with alignment options.
Also, I’d like to propose a “snap to grid” function. This could work by enabling it as a preference setting. When it’s active and you’re using a click-drag action, objects would automatically align with grid points on the plate layout. Alternatively, alignment guides could appear as objects approach alignment with each other, much like how PowerPoint handles it, as shown in the example below.
This feature seems pretty essential to me, when designing complex technical prints that must be precise. Use the alignment features in MatterHackers all the time.
No question, when it comes to combining positive or negative parts, an alignment function beyond center is needed. I thought about snap to grid, and that would be a simple way to do it.
I’m surprised it’s not there already. I was looking for a tutorial on using it when i found this. Kind of a no brainer. Also distribution. I print a lot of the same thing and when cloning it puts them too close together.
If you haven’t already tried Orca Slicer there is a “fill bed with copies” feature. This won’t address the clone spacing problem but if you’re cloning several parts you can control the spacing of the parts in the alignment menu.
I imported parts of my model as separate objects so I could color them and then add them together, but aligning them has been a huge issue. I would have thought this feature would already be present in Bambu Studio!
I need to precisely align some negative volume to a object’s center, it really should be more easy with some align tools.
I managed to do it with difficulty on Prusa Slicer, and then go back to Bambu. What a pain.
This would be really useful. Often I find the auto arrange function makes some odd choices on item location and splits out into multiple build plates. I don’t mind manually placing items but it would be good to have tools to help me alight items with each other.
For me it would even be helpful to just choose left/center/right alignment because i get it all placed in the spot near the edge i want. Then i change the text to something longer or shorter and it throws off the alignment that i just created! If i could do left aligned for example instead of center being the default it would solve a lot of my problems.
I would also like to vote for alignment for objects. For example you split a model to make one of the sections thicker, it’s nearly impossible to get them to line up and be able to move the thicker item up to stack on top again. The only way I’ve been able to do this is to export each part as an STL then in Tinkercad do a realignment. Then export that to an STL and back to Bambu Studio.
Thanks
M1
I was just trying to do this today, where I’d love to position one of my items on top of another, perfectly aligned. It would be great to have alignment tools
thank you, yes I saw that and read the wiki page. I was having trouble with that feature showing when I selected my parts but in thinking about it, it may have been because it was more than two pieces selected…I’ll have to try again.
I’d also like to see a snap-to-face for the assembly. Rather than manually trying to position things, to be able to snap to the surface of the other object. An example of something I was doing recently was making a lightbox and I would have liked to have my white diffuser simply printed in place inside the box vs it being a seperate, removeable, piece. It would have added further rigidity (i think!)
