Allow manual control of Aux fan on “heating mode”
The aux fan control is not possible through the screen nor through the app when it is heating mode. It is possible through slicer filament profile settings.
I understand that the aux fan is generally not used on filaments that use the heating mode but there are times where it is useful to be able to control it. It seems like an unnecessary precaution to lock this feature out.
For example - if I want the chamber to heat up faster (and it takes quite a while to get it to 65!), it will be useful to be able to blow air across a plate that’s been warmed up to 120 deg.
I’ve encountered another odd issue: after a print finishes, I use the exhaust fan to vent the chamber. However, the fan can only be turned off by first switching to cooling mode. It would be very helpful if a timer function were available to automatically shut down the fans after a set period. As it stands, the only option is to walk over to the printer and manually switch to cooling mode.
…would also like this feature
Yes! This and independent control of the heater fan as well. The heater fan turns off when the print is finished, but I’d like to turn it back on so it can continue to scrub the air in the chamber for a bit before I open up the door.
That and the option to vent the chamber to cool it down
Man I know you commented this 2 months ago but I REALLY wish this was a thing.
That, and running the AUX fan in heating mode for those of us who have turned the AUX fan into a scrubber.
Haha I’m still wishing they’d make it a thing.
You can use the aux fan in heating mode by setting what you want it to run at in the filament profile. You won’t be able to adjust it when the printer is in heating mode, but it does turn it on.
Yea true, but I hate that I have to make custom profiles for all my BL filament just to do it…
here in 2026! pls make this a feature on the P2S!
