Almost good
Welcome Everyone,
I’m totally new in this Hobby and I tried first print (other than printer improvements).
In overall it looks nice, but maybe someone can recommend me how should I adapt my settings to receive better quality in top layer and avoid “granularity” on some statue area.
Printer used: P1S Combo;
Filament: Sunlu Slik PLA + Dual Color (Red Gold);
Model: https://www.thingiverse.com/thing:4543820 (I added tree support as suggested by the printer ;))
I used settings recommended in this post: Printing with silk filaments | Bambu Lab Wiki
Thank you for support and comments.
Re layer lines, I’d use adaptive layer height.
The spots appear to be from random seams. Try aligning it (paint on) and experiment with scarf seam with a well dried and Pressure Advance calibrated filament while enabling wipe when retracting in the filament settings. You can not fully eliminate the seam, but you can hide and improve it.
:crossed_fingers:
for the top make sure to select concentric top surface pattern(under strength tab) then select “not applied” on this drop down (under the quality tab). Select adaptive layers at top of BS and slide the top slider all the way to the left(quality) and click the adaptive button near it
Thank you for suggestions, will do that next time!
Good tip, will do than next time. Thank you!
