I have just gotten a AMS 2 Pro with the power adapter and it’s connected to my A1, I’ve searched here, the web and the wiki for the answer and nothing ? The question is can you use the dryer whilst printing when connected to an A1 or is this just for the latest printers ie P2S ? when I click on the humidity icon in bambu studio there is no option to start drying ?
Do you have the option to dry whilst printing in the printer ?
@MoriArti I’m pretty sure that they don’t let you dry during printing. If I am correct, they say it is because the power draw or something like that maybe?
I don’t think this is possible yet. They just added the ability to the P2S in beta firmware, so i’m guessing it’ll come to all machines eventually.
Thank you this was the answer I was looking for.
I think the majority of people are not ready for drying filament while printing.
Here’s why:
Normally, you dry PLA at around 45°C. At that temperature, you can’t realistically print—it becomes too soft, which leads to issues like clogging, deformation, or filament getting chewed up. It’s simply not reliable or efficient for consistent prints.
So what temperature would you dry at during printing—40°C?
We’ve already seen countless cases where people report extruder problems, and after troubleshooting, it turns out their chamber temperature was creeping up to 40–41°C. The general consensus has always been clear: you can’t print PLA in a 40°C chamber—it’s too hot. Even with systems like the Bambu Lab P2S running at 30–32°C, people already question whether that’s pushing the limit.
On the other hand, drying PLA at 35°C takes a very long time. It’s definitely not sufficient for taking wet filament, putting it into something like the Bambu Lab AMS 2, and immediately expecting high-quality results.
PLA users arguably need proper drying the most, but that doesn’t mean “on-the-fly” drying is the solution.
The engineering crowd already understands this: for best results, you need to dry filament properly at the correct temperature, typically for several hours. Drying during printing simply cannot match the consistency and reliability of using filament that has been properly dried for 6–8 hours beforehand.
I believe the default is to dry at half power, so around 20’c, but at that point you’re basically not really drying at anything above room temp so its not really going to “do” much
Thank for the detailed explanation I was wondering if something was not configured correctly as I had read a little while back that an update allowed drying whilst printing but as someone else here pointed out they believe that was just for the P2S..?
Im also looking for the answer for this. Do A1 have any new fw that allows drying and printing at the same time now? Or if anyone has an AMS 2 pro with an A1 machine, can help me check if we have an option to remotely turn on the dry function on Bambu Studio?
Updated 5-Jun-2026.
I bought an AMS 2 pro and connected it with my A1. It doesn’t support both drying whilst printing and remote drying from bambustudio. So sad ![]()
Hello all,
I bought AMS2 Pro with A1 kit and I will receive this week. Unfortunately I saw that on this topic “dry whilst printing” isn’t available on A1 and this fact is confirmed on the wiki (search for paragraph Introduction to Simultaneous Drying and Printing Function in the wiki)
I’m interested to this function because I want to make long prints (weeks) which works day and night. So it is important to me to have continuous dried spools.
Any suggestion about this?
A first idea is: keep the spools dried in the AMS, and activate once per day like 5 hours drying cycles, and use the external spool to print.
Another idea: use the AMS also for printing 20hours/day and 4 hours/day drying.
no answer?
I also would like it!
You’re misunderstanding the problem and trying to fix something that doesn’t exist.
Dry your filament fully. Put fresh dessicant into the AMS, either the little bags from Bambu or print yourself the AMS dessicant holders that are all over Makerworld.
Put your dry filament in, close the lid, and do your long prints. It’s really that simple. The AMS has a fully gasketed lid, there isn’t an opportunity for humid air to get in there, so where is moisture coming from that you need to be drying to remove it mid-print?
I am not misunderstanding ?
The AMS 2 Pro has a “drying function”
Reports say, one could use it not only isolated, but also when printing an object
on the bambulab A1
