Dear Bambu Engineers
You’ve made the process of removing a broken filament from inside the AMS unit far too easy.
There is far too much slack on the two cables and the pins are far too big making it way to easy to insert them back into the sockets.
There is also far too much space when trying to put the reel holder back into the casing.
Going forward I suggest making the cables so short they don’t even reach the sockets. But even if they did, the sockets should be so small you couldn’t even see them with the naked eye. Then the inside unit should be made bigger than the outside case so you have absolutely no room to manoeuvre
Please bear this in mind on the next version - I look forward to it being much more challenging and even more frustrating
