Hello friends / Bambu Technical support ,
I have a problem with my printer X1C, after ten minutes of printing, the AMS disappears and the red light flashes in all places of the spools, and there is no AMS in the Bambu Handy App or in Bamboo Studio or on the printer screen with the message AMS is not connected with all that, the printer continues to print and change colors normally??
Please Help.
I have not encountered this or remember anything similar being reported. Has it happened on multiple prints? Did it only start happening after the latest firmware update?
Things to maybe try:
Reboot the printer by removing power for a minute then plugging it back in
Reseat both ends of the AMS cable
If possibly firmware related, try reverting to the previous version and then reapply the current. I had a previous firmware that did not fully apply correctly and it was solved by doing this. This latest firmware release included an AMS update as well.
I had a similar problem as yours. I first checked the cable connections. The problem still was there so changed out the cable with a new one. Problem was fixed for me.
I’ve tried all of that and it doesn’t work.
Do you mean a connection cable between the printer and the AMS or the AMS internal cables?
Printer to ams. Since i have two ams it was the cable between the two ams.
No. It will request you to do a manual change.
However an AMS “reboot” is likely to solve the issue and allows to continue printing.
Disconnect the cable (buffer to printer) cable in the printer side and plug it again and/or the AMS to buffer cable.
I am having the same issue, but still unsure of the cause, even so the most likely is the cable followed by the boards.
I had this same issue early this year, drove me nuts and spent hours trying to isolate it to one part. After trying cable and AMS hub swaps which did not work we eventually swapped the small AMS interface board just inside the back of the printer and the problem hasn’t happened since.
Yes, the printer continues to operate normally and changes colors automatically, and it appears on the printer screen that it is printing from the external spools.
Thanks for sharing; it works differently from mine.
It’s odd, as four red lights mean faulty communication, so the AMS shouldn’t work.
And the printer, knowing that it does not have an AMS, should require your intervention.
just got my x1 carbon… AMS doing identical BS. I did all sorts of things to fix it. spent a long time and almost took a sledge hammer to it just for fun! I managed to get it to work but nothing I did was the obvious fix… Guess I’ll wait and see how long it lasts. I had a P1S before this one which was also new and the AMS worked perfectly. This is the same AMS so no idea what’s up.
Have you checked to see that the AMS is updated to the latest firmware? An older AMS interfacing with a new machine might be part of the issue.
Hello, I am having serious problems with Bambu Lab x1c. I can only print 1 out of 3 prints. Today, I noticed that there was an extra 30cm of filament left in the PTFE that I last used 1 month ago. Very serious problems. I don’t know why it does this and how to solve it. There is a different problem every day.
This might be a solution. For months, my two AMS units on my X1C will occasionally disappear, sometimes in the middle of prints with all slots flashing red, and various errors regarding filaments not pulling back etc. When printer is idle, occasionaly spools will pull in and out, as though the AMS was just turned on or connected. Problem has been slowly getting worse to the point where no prints were succeeding. Tried swapping cables and parts, every permutation of connections, resets and firmware with no luck. Two days ago I did a factory reset on the printer and so far it is working. Did an 8-color print overnight and it came out great!
Update, Factory reset is only a temporary fix, but the only temp fix I have found. After a few days the problem comes back. Ordered replacement communication circuit boards for both AMS units, new cables, different AMS hub, nothing works except a temporary lull after a factory reset.
My AMS disappears when I open certains files from the internet. 3mf seem to be the culprit. After trying a few things I power cycled my router restarted Studio and my AMS reappeared. Load the file again Poof AMS is gone.
Hey everyone, I had the same problems for over a year and gave up on my AMS a while ago. I’ve tried almost everything in this topic to no permanent solution. In my last attempt, I noticed that whenever the printer vibrates frantically (mostly in auto bed leveling sequence) my AMS gets disconnected. Even after passing that moment, whenever astrong vibration occurs there is a possibility of a disconnection.
I’ve removed AMS from the top of the printer to a side table. I am running a 15 hour test print with 4 different colors. So far, everything works perfectly.
TL,DR; I think the problem is sudden vibrations from the printer. Try moving AMS to a different location, where it won’t be affected by the printer’s movements.
Hello,
I have troubles with P1s+AMS, too. It worked fine for one year, but now AMS is starting to disconnect from the printer. Cabel was checked, and vibration was minimized. The issue appears mostly after a few hours of printing. But not always. Turn off/turn on p1s fix it.
Ive had my printer for months now without issues using the filament buffer that came with my combo… I bought the ams hub since i purchased the ams HT and now i am having this issue… the og ams disappears but the HT stays connected. Im guessing no one found solutions.
I got the same problem.
Getting HMS error as drscribed under P1 Series.
Think this is generated by latest firmware og latest Bambulab Studio.
Will try to downgrade both…
