Is there a way to stop ams from retracting filament after print is finished and purging before a new print job. I mostly print single color prints and no need of retracting filament after job is finished or purging.
Looking at the machine end G-code it seems that this process is done with several G-codes. but it seems totally editable to do what you’re trying to accomplish. I personally like this feature as it makes swapping filaments a total breeze. But if you’re not swapping often i can easily image that the “unload” function works just as well.
I would advise to carefully figure out what the codes do as i don’t think Bambu provides a clear wiki on how their custom G-codes work. Good luck and maybe post your results for others to use if you’re successful ![]()
