So I got my AMS HT in yesterday. I have spent a lot of time calibrating my filaments on the left nozzle (that were previously on a spool) and they are visible in my calibration results in Bambu Studio. When I put the filament into the AMS HT (for non-bambu), I set the type, the color, the profile (that I have calibrated) and when I go to print, I no longer see a warning if “Flow Dynamic” is set to AUTO as I send the job to print. Previously, I’d get a warning that using AUTO would override my calibrated flow rate. It’s not a big deal as I usually set that to OFF as I know I have it set up, but curious why it doesn’t seem to recognize that it’s there in the slicer. Was working fine prior to going to my new AMS HT and I have not tried this with the spool again. Anyone else noticing this? Is this a bug? Design? I just set it to off when I print because I know it’s there but the warning was useful if I forgot to change it to OFF.
Mine tells me in small red text above the check boxes.
Mine used to as well, but it doesn’t any longer which is interesting to me.
Is your calibrated value chosen in the ams filament menu? Maybe it reset for some reason
It is. I double checked that and prior to my AMS HT, if I had something on that left spool my slicer would warn me if I was using Auto. I double checked it all, same settings and it no longer warns me. I’m not going to lose a lot of sleep over it, just an interesting observation.
