AMS Hub needs 5th slot
AMS Hub needs a 5th slot for external spools. Adding a Y adds friction.
You don’t need to go through the buffer/hub for an external spool, you can just disconnect the PTFE tube from the hub. Also why would you need an external spool with 16 AMS slots?
because TPU doesn’t work with the AMS?!?
But you can’t feed it through the PTFE tube and buffer anyway right?
Yup, unless one goes for the newer TPU filament version released by Bambu, which (at least in theory) according to Bambu, could potentially be put in the AMS. Haven’t tried this new TPU though, as of 18th of January, I’ve stopped ordering any Bambu made products… at least until my current stockpile of spares runs out.
I’d be interested to learn if someone has used the new TPU with their AMS and what problems did they face (if any).
ā€œYou don’t need to go through the buffer/hub for an external spool, you can just disconnect the PTFE tube from the hub.ā€
  1. Sure you can. Clunky and not very convenient.
  2. The tube is scarred every time you remove it and you leave little bits of PTFE tubing behind in the coupling.
ā€œAlso why would you need an external spool with 16 AMS slots?ā€
  1. To run a spool that won’t fit in the AMS (which also needs some improvement/ rethinking).
  2. Save the trouble of having to swap a filament out of the AMS
  3. Run TPU from other manufacturers. Bambu’s color range is limited.
  4. Some of us only have 1 or 2 AMS units. haven’t seen a need for more. Yet. Even then see 1 thru 3
here you go
I only have 2, but I assumed you had 4. Since it seems you don’t have 4, then why don’t you just use an empty slot that’s not being taken by an AMS?
lol. I’ve got the 4 AMS setup, but I rarely get to use more than 8 colors (even 8 not that often), so one could say that I’ve got 2 + 2 units, where the later 2 are practically spares.
Honestly at that point I would just buy another printer and run 2 on each, I am assuming you already have a bunch though lol.
I’m not running a print farm, if that’s what you are saying, but i do own more than the X1C…like a Prusa XL and an Elegoo Saturn 4Ultra… I was considering going for H2D if proven a worthy and reliable succesor of the X1C and handing over the X1C to my youngest son, but since the firmware scandal, I’ve changed my mind about acquiring anything from Bambu and looking more towards K2 Plus, or the Core One… I’m not decided yet.
I built the Bambu 4-in-1 PTFE adapter in between. It works without any problems.
In the background is the AMS hub for ā€˜poor people’.
In the foreground is the Bambu 4-in-1 PTFE adapter. The right hose is for the external coil, the left hose comes from the AMS buffer.
Sorry for the poor image quality.
What do you mean by built it? Is it 3d printed?
I have supplemented my text once again. Didn’t copy everything the first time.
Well, dunno! New to Bambu so I don’t understand the function of the hub at this time. I see some are running multiple AMS without it. When I got the second AMS the website redirected me to the hub and intimated I would need it. Obviously it has sensors and an MCU. I assumed the firmware was meant for AMS and not an external spool. Would it prevent a collision if one had an external filament spool loaded and sent a print job for the AMS units?
The 4 in 1 adapter is used with the AMS Lite?
Be a smart move to port the AMS to other printers.
That’s the point of concern, as tunnng the AMS to work with other printer brands isn’t something to be taken lightly.
I have different uses for TPU that don’t include making golf balls. (Referring to the hardness shown in the video above.) That’s what Shore 68D is equivalent to. In fact, I don’t even consider a TPU filament that’s measured in the ā€œDā€ scale. If I need something that hard or tough, I use ABS, PLA or a Nylon.
That’s not to say it doesn’t have a place. Just not for me. :face_with_diagonal_mouth:
I Made this simple mount for the Bambu Lab 4-in-1 adapter - making it easy to switch to external filaments without having to mess with the sticky PTFE tubes in the AMS Hub
Search Makerworld for: Bambu 4-in-1 PTFE Adapter A1 AMS Lite Inline Mount
