AMS Issues with Filament Settings and Sync
X1C (01.07.01.00), AMS (00.00.06.40)
2 Filaments Cal’d and saved in Slicer
Filaments also saved as Custom Filament
Both available in Slicer Prepare Tab Filament and where visable in the AMS section of the Device Tab. You could select them from the drop down menu.
Everything worked fine and no issue. But after several days the filaments and sync had issues.
AMS has both spools loaded.
In Prepare Tab pressing sync shows only 1 generic spool in AMS.
In Device Tab on AMS the saved filaments are not available.
When you select Generic Filament and load saved PA Profile into the AMS section it will drop all setings out after about 5 secounds.
If you put settings in and quickly go to Prepare Tab and press sync it still only shows 1 generic filament.
AMS will only show 1 filament nomatter how many spools are loaded.
Started having this problem about one or two weeks ago. Didf you ever get an answer?
It was a bug in the software they fixed, then it broke again in the latest release of Stidio.
