I have been having issues with the AMS unit on my BambuLab X1C.
The filament breaks deep inside and I have to remove it by disassembling the AMS unit, flipping the unit upside doen while I remove the broken filament stuck in the tube before the 4 way adapter. When the spool retracts, the filament stuck inside registers an error. Now this has happened on another spool.
Recently, I have added Slice Labs dessicant spools which fit into the open space. I just relaized there may be too much drag on the spool as it moves back and forth. I may remove the spools as I have the dessicant chambers in the chambers between and humidity is 16% with the reader I added in the one chamber in the front center.
I want these 3D prints to be plug and play.
Thanks in advance dfor the help!
MagicBill
