After deconnecting and reconnecting the ams - because of broken filament in the extruder - the printer doesn’t find/connect the AMS.
The red lights in the ams are blinking.
I changed the plug, I switched the printer on and off, but nothing changed
Does anyone please have any Idea?
Although, the quality and speed of this printer are very good, I never had so much trouble with a 3d-printer
Problem solved:
one of the two bus-cables inside the ams was disconnected
depends on if you unplugged the power from the printer first or just went to snatching cables and tubes first tbh, if you powered it down you should be able to do a power cycle and as long as you hooked everything back up and in the correct positions the machine should be none the wiser, if you pulled wires and didn’t power down you have different issues
