I haven’t been able to get the auto-refill to work on the A1 AMS Lite. It’s switched on in the AMS options and I’ve specified two of the spools with exactly the same filament brand and type, but it didn’t auto refill and instead prompted me to replace the spool that ran out (which worked fine, but needed my attention).
Is this fully implemented on the AMS Lite? Or perhaps only works with Bambu Labs filament? (I specified the two spools as eSUN PLA+ with exact same colour)
I found this post but I am also having the same issue with no luck. I have tried many things, like now its out and im stuck at work with three full filaments on stand by!
I just started having the same problem with my A1 Mini AMS Lite. The “Auto Refill” worked twice a couple of weeks ago, now it doesn’t. Both on the printer and in Bambu Studio I see two of the same-colored spools, but it won’t switch over. I now must swap out the empty spool in the same AMS slot.
Same problem with my A1 and AMS lite. Even if I set the same color, manufacturer and type. The printer just waits for the spool to change instead of continuing to print from the other spool. Only tested with other manufacturers. I have not tried with the official bambulab filament.
Same here, I used a coupe of times with a generic PLA filament and works, but now with PETG doesn’t work it, even with pre-defined PETG in the filament AMS lite section.
Also just experienced this with Bambu filament too - It always works fine on the normal AMS, even from different AMS!
I have it all set up properly, auto refill shows me what it will swap to, come in in the morning “AMS slot 4 is empty…” and an unfinished print - no ■■■■, you were meant to swap to slot 1!
I’m experiencing the same thing. I bought the A1 with AMS Lite specifically to take advantage of the auto-refill feature, and it doesn’t work properly. Sometimes it uses all the spools, but many times it doesn’t. Honestly, I think it’s pathetic that they can’t fix something so simple.
I never had an issue with the auto-refill and I am using Creality PLA-HS filament. I am also running firmware ver 1.5, because they haven’t released a fixed ver 1.6 yet.
