I had a part roll of PLA white loaded on 1 and a full roll on 2. I expected when 1 finished it would load 2 but it wouldn’t. I had to physically remove the roll from 2 up to 1.
When I checked, the system had decided 1 was white and 2 was black and no matter what I did it would not accept my changes to tell it both were white.
Is this an RFID problem or am I doing something wrong?
Every once in awhile, i have to reset the slot I’m trying to use. I do it from the printer UI.
I load the new spool. Wait for it to load the filament in the AMS. If it doesn’t pick the right color, i do the slot reset. Then pull the filament out and reload to get it to read the RFID tag correctly. This usually works for me.
If they’re BL spools you don’t have to tell the printer anything. It will know, then transfer that info to the device tab in the slicer, you just need to choose “synch” to import those colors to the slicer. In the device tab the slots will show what color they are from the printer and the RFID tags.
You didn’t answer the rest. The printer will detect the colors but only if you load a new spool with the system running and not filament loaded. If the printer doesn’t show the right color loaded it won’t work unless you fix it / reload properly.
