I loaded a roll of sunlu pla into my AMS lite, but it’s not showing up on the machine or the slicer. I restarted everything, loaded and unloaded it, and still, it appears to be empty even though the machine loaded it in. Have you seen this?
Only Bambu filaments use the RFID Tags, you will have to edit the colors manually.
That’s not what I mean, it’s not even showing a spool is loaded.
Try switching to a different slot to see if it works.
I am only using bambulabs filament and it wont detect anything. Even in studio when i press the refresh it doesn’t. it also thinks i have an external spool connected which i don’t.
Having the same issue with my AMS Lite… did you resolve your problem?
Yes i have. The other 3 positions work correctly, position 4 is the only one that is unable to detect that a spool has been installed.
Thank you for that! I decided to try another spool on position 4, and it recognized a spool was loaded. Not sure what happened, but all appears to be working correctly now. Thanks again for your suggestions…i will definitely screen shot them for future reference
Have a blessed day!
