AMS lite position reels
I wanted to ask, do the original bambulab reels with the tag have a mandatory position on the ams lite?
I ask because the tag is only on one side of the reel, so if it goes outwards will it be read? Also because the coils only have an engraving of the material on one side with a printed scale indicating the remaining weight in grams.
If your loading filament on the AMS Lite…
You will see that 1 & 4 load the same and 2 & 3 are flipped & load the other way.
So, the tags are fine. As for the labels, unless they are printed on both side there is always some that face the AMS & some that don’t.
This means that I might have to insert some spools with the tag facing out if I have 3 positions full.
Bambu says there are tags on both sides.
End of video shows both sides:
