AMS Not Recognizing new PETG HF
I have seen this issues before in the threads but those threads didnt help solve the issues.
When I load PETG-HF into my AMS it flashes the correct profile then goes back to a white ?. Even manually editing it stays for about 5 seconds then goes back.
I have shut down all instances of Bambu Studio. I have made sure the profile has been checked in Bambu Studio.
My firmware: X1C is 1.08.02.00. AMS Hub is .43 my AMSs are 6.44
Not sure what else to try ?
I have not experienced this and have used many different colours of PETG-HF.
I do occasionally experience a failure for it to detect a spool, this is not restricted to one type of filament.
Remove and resit usually resolves it straight away.
That is an excellent reference to U.K. TV at it’s sarcastic best.
it’s a great show :smiley:
Tried that, many times. Thanks anyways
Yeah, this was the exact behavior I experienced with an instance running in a docker container that I had forgotten about. I found that it WOULD work in LAN only mode before I figured out I had a forgotten instance. You might give that a shot, just from a troubleshooting standpoint.
Yes I did consider than and shut it down. However just realize I was also running an Orca instance, so I will try to shut that down to see if it works.
If all else fails, what I would do personally is carefully open the spool so that it won’t become a tangled mess and remove the QR code, maybe it’s defective and causing an issue, then you just assign manually
Yep that was it, I had an instance of Orca running in Docker on Synology NAS open. Once I killed that job everything works.
now I’m curious, why do you run orca from the NAS? Asking because I have one myself but not understanding the use case
I run Orca and Bambu from NAS (I also run Studio on a laptop) so it can be accessed on any of my devices. Either to check the status of something or do a new print. Also my daughter is in school for engineering so it is just easier for her to go to a web page and import a model than to load up Studio.
Cool thanks, even though I don’t really need it, I might set a container up just to play with it :slight_smile:
