AMS Pre Feeding Buffer Adapter
They look so awesome in my AMS buffer!
These little adapters have now officially saved my butt and my feeders are working so much better now!
Time will tell but I’ll run a few long term prints and see!
Your support and feedback is highly appreciated! So far i haven’t heard any negative responses and still testing the final design but it’s looking like they will functionally work!
v2 now uploaded with a locking lip on inside to help hold in place!
https://www.printables.com/model/306625-bambu-ams-feeder-pfte-adapter
is this to prevent pushing on the yellow thing to feed the filament ? or is it just something extra you put on it ?
it looks nice, but i wonder if it wil preserve the original function or that it just bypass it
These are a great idea. I saw one user who had worn groves in the actual AMS feeder holes from a very long print. This use of PTFE tube will definitely save that.
Thanks
There are few issues with this. As shown, it looks like Capricorn tubing which has a small inner diameter (<2 mm) and resists flexing. I had several spools that would not feed in this arrangement when nearing empty - ABS and PETG. I switched to the Bambu Lab PTFE with a large inner diameter (2.5 mm) and shortened to have about 1 mm above the opening. This worked well with my ABS and PETG filaments. As a test, I then tried PA-CF from Bambu Lab. It absolutely refused to feed reliably in this arrangement. Removing the PTFE allowed the PA-CF to feed, but bypasses some of the intent to help reduce wear on the first stage feeder input opening. I’m running about 250 g of PA-CF now and will check the amount of wear on the cap versus the input opening. This may just need to treated as a consumable for the feeder.
Printed them out and it doesn’t seem to work as expected. Every time the roller retracts the filament the adapter pulls up.
Mine fit tightly - printed in ABS. It might be worthwhile to add a small lip to help lock in place.
Are the CAD files available?
I have ASA, I’ll try printing them with that…
I have added a v2 with these options as others comment and suggest improvements which helps to get the final design.
I can look into another version with a slightly larger OD for that type of tubing!
