AMS Problems
Hi guys , I can not get a connection to the printer via the cloud.
Now my problem. Gcode saved to card and passed. now when I want to print the file I can’t specify the tray on the printer , it shows me a picture of how to do it but that window doesn’t appear.
It always wants to print from tray 1 only. What can I do.
Thanks in advance.
Before you slice the file go to objects
You will see the slots and color selected from the AMS on the right
Double click the box beside the item (sometimes 3 clicks for some reason) and you should be able to choose your slot
Then slice
Then send to the SD card
That should work for you until you’re connected again
ALSO/OR -
Once the object is highlighted, just type in the number of the filament that you want on the keyboard, then press “tab” (might have been enter) will drop you to the next one.
If you have multiple you want to change, after selecting the topmost one, hold shift and click the bottom one then type the number for the color and it will change all of them.
