Ams syncs with device on screen tab but not the studio
Hi
I have and issue with my synchronization in bambu lad using H2d the Ams reads as should on the device tab, but doesnt sync properly with the studio main screen am i missing somthing ?
You can read the wiki how mapping works but I don’t like the way it does it (may be I’m unresponsive to the concept…). Otherwise, if you want to see the filaments as they are loaded, click this icon, select “Overwriting” at the top of the pop-up window and synchronize.
Hi
Im aware that i have to press the synchronize button,
As this was the first thing i tried to do , i also tried to log out on both devices printer and desktop and ut still doesnt recognize the diffrent filliment as is
Sorry if it was obvious. Have you tried to restrat the printer?
If you have more than one Bambu Lab printer, only the connected one will sync, regardless of what you selected during the setup or preparation stage.
I have restarted the printer i restarted the desk top and still cant get it to work ,AMS all over the place shows 6 slots when i only have 5 and has them all mixed up not sure whats going on ?? I had a Bambux1c till up to now never had an issue
I only have 1 bambu the h2d at the moment and still cant get it to work
Ams shows everthing correctly but the main tab in studio shows diffrent
Are you syncing using the overwrite option?
If not, Bambu Lab Studio will attempt to map the filaments you have selected in Studio with what is currently loaded in the printer.
Try clicking overwrite — this should correctly detect everything loaded in the printer.
Mapping works well if you have the selected filaments loaded, but not necessarily in the same order or color.
I am having the exact same problem with my H2C. Has anyone figured out a solution?
