P1S, bought it and the ams refurbished from Bambu, has worked fine until last night. Initial troubleshooting I tried to push the filament up to the extruder, would not go. Tried a couple of different spools, same results. Watched a video about how to remove a piece of filament oin the feeder so I disassembled the ams. Did not find any scraps of filament.
It seemed that the filament would not pass the feed wheels in the ams, so I removed the screws that hold the idler wheel in place, and I was able to push the filament through easily. Again no scraps of filament. Used dust-off to blow everything out. Removed the gear-motor assembly, everything turns freely. Reassembled, found that filament has a hard time getting between the feed wheels, almost like the wheels are a little too close together. Once the filament is between the wheels, it will move easily. I can turn the gear with my finger and move the filament back & forth.
Put the ams back together and mounted on top of the printer, will not feed the filament.
I’ve had a couple of times my AMS2 Pro’s won’t feed, but it’s at the beginning of feed. I have just pulled back the filament and trimmed it back a smidge and it usually fed after that.
Other times a filament will stop at a joint where the PTFE tube is in a connector. Most often just pushing the PTFE tubing into the connector sets it squarely with the connector and it successfully feeds after that.
The only other suggestion I can offer would be to see if the PTFE tube is constricted some way. If you can maybe try changing the tubes and possibly find the constriction. (Since you have tried two different spools of filament) Maybe try some different filament still.
A refurbished AMS may have been returned due to a feeding problem and the tech who checked it out missed a tight throat in the unit. There has to be something wrong.
Makes you wonder if they actually did try to function it during the refurbish, or just powered it up to see if it lit up. Sorry you are having troubles.
Problem with that is … and what first alerted me to the problem … it won’t feed on a color change.
No ■■■■ sherlock.
I have opened a ticket and have had a response, submitted all the data they asked for. Except a video … how do you submit a video of the printer not doing anything?
That is a standard Mandarin request. I do think they hope the ticket holder will just go away. I got that on a ticket for a piece of Astronomy equipment I sent it for it being faulty. And there was, just like here, no way to submit a video. So what I did was to make a training video for them, put it up on my YouTube channel, and submitted a link to my video. That worked, it trained their half-baked technicians, and they replaced the faulty focuser with a new one. Which was what I requested in the first place. It’s what I call “The Chinese business model.” Offer a 2-year warranty, then cut you off when it comes time to honor it.
No chit, donut hole. You could try my work around. Signed, Sherlock (I don’t give up easily.)
I have an AMS2 Pro with a noisy fan in it. They wanted a video. I said F-it. After several minutes it stops making noise. But the Chinese business model is the throw of the dice we all take with most of the things from China. And you don’t even want to hear about my Vevor experience.
