Here’s a (rather very hacky) workaround for those affected by this.
DISCLAIMER:
- Backup any files you modify
- Do this at your own risk - this worked for me, but there’s no guarantee it hasn’t broken something else…
- EDIT: Don’t do this unless you’ve followed the filament cutter lever stowage instructions here: Print volume limitations, and how to use the full build volume 256x256x256mm³ | Bambu Lab Wiki (As pointed out by @Alex_vG)
The process…
Browse to the machine settings folder:
C:\Users\{..your username..}\AppData\Roaming\BambuStudio\system\BBL\machine -
Pick the profile you want to use and create a copy, name it something meaningful:
Open the file; update the name to match the file, override the inherited exclusion zone as shown below:
** I updated the “setting_id” to the (seemingly) unique value “GM006”. Not sure if this is necessary… -
Add a section to the config manifest for the new config (use the section of the copied config as a template):
C:\Users\{..your username..}\AppData\Roaming\BambuStudio\system\BBL.json
** Ctrll^F is your friend on this one
Re-load Bambu Studio and select the modified config:
Hopefully your exclusion zone is gone:
Go do something nice for someone.
