Any hope of Studio ever allowing us to customize the mouse buttons?
Having the mouse buttons on Bambu Studio being different from my other CAD software is annoying and wastes time. The primary mouse button serves one of two functions (move or rotate), depending on where you happen to click. That is especially bad.
Is there any hope that Bambu Lab will eventually let us customize our mouse buttons?
Your mouse software should allow you to ‘application specific’ set each button to do whatever you want it to. That is the job of the mouse, not the software application.
I fully agree with the OP! It is so annoying. Especially, since middle and right button have the same function move, while the left mouse button has two functions. if they leave everything as is but assign rotate to the middle mouse button, I would already be much happier.
That is not right, how should you reassign in the mouse driver, how the application uses the buttons? Maybe you can swap buttons, but that doesn’t help here.
That is incorrect. Adjusting the mouse buttons directly affects all applications using the mouse. I want to fix just the Bambu Studio button assignments.
Better mouse software allows for application specific mods. I know because I’ve used good mouse software that does it right.
Heck, even Microsoft does some things right sometimes.
That would be great if I used a Microsoft mouse. It doesn’t work with my Logitech. Bambu Studio should provide the button options, just as all my other high end apps do.
RAmeeti seems to have a Microsoft mouse, to which he can change button actions based on individual applications. His suggestions don’t work if you have a mouse that is not Microsoft.
Yes, but that is only useful to swap mouse buttons or assign some generic functions or e.g. keystrokes. It can’t add functions that aren’t in the application. In Bambu Lab there are no isolated functions for rotating or selecting, so the mouse software can’t assign them to a button either.
Your suggested solution doesn’t fit the problem!
Bambu Studio is fully open source. If mouse customization is really important you can fork the repo, make the changes you desire and recompile.
I wish that kind of programming was in my tool belt, but it’s not. I wouldn’t even know where to start.
#learntocode
like seriously what low IQ pesant doesnt know how to fork a github and compile their own fork just ro re-keybind basic navigation keybinds. pfffft. Oh and re-compiling every time bambi pushes us an update every other week for more color mixing and filament tracking features that we neeed so deperately.
What part of “if it’s really important to you” is giving you the most difficulty?
We know that Studio doesn’t currently support this. The OP seems very determined to not use the capabilities built into logitech software (that can totally be set up on per-program basis, by the way), so what’s left? If it’s important, this is an option.
…and who said they need to do every update? You yourself seem to think the updates contain low value features, so by your own admission there would be no need for having to do this every time there’s and update.
Seems you just want to be argumentative more than anything. There’s definitely much newer stuff if that’s your goal.
Holy Thread Necromancer, batman.
The Logitech Options+ software I have only allows swapping of the left and right mouse buttons. It does not let you assign different functions to those buttons; in Studio, we are stuck with Rotate and Pan on those two buttons. The middle button (scroll wheel) and any other buttons can be assigned keystroke commands and other functions, but none of them will detect mouse motion while the button is pressed. The Logitech software will not solve the OP’s frustration with Studio.
OrcaSlicer provides more control options:
