Any one come across this?
Hi guys. I tried to print a mask with a new esun pla+ on .16 optimal left everything eles default but im getting somthing like coasting or not sure what it is? Here are some pictures hope you guys can share some of your experiences with me since i just started to print. Thank you guys
Looks like wet filament. Dry your filament.
Make sure you use the eSun profiles from their website. So far they’ve been perfect for me when tested for pressure advance and flow against my own tests. 3D Printing Settings - eSUN 3D Printing Materials
I doubt very much if it’s wet filament, more likely the flow calibration is off and you’re over extruding.
Dry filament will definitely improve the result.
Thanks for the replies. When that happened i tried the exact same setting on a benchy and it came out perfect.
Could it be the creators stl file?
Not sure if its a hardware problem?
