Hey all! I’m fairly new to 3D printing, so appologies in advance if there’s some simple setting i’m missing here.
I’m creating some pixel art artwork, and on certain sections of my models, there’s some gaps in the corners i’m trying to fill.
The images illustrate the problem areas with a 0.4mm nozzle and the 0.2mm nozzle. I thought the smaller nozzle would solve the problem, but they’re still there, although they are a bit less noticeable.
The things i’ve tried are setting my wall generator to Arachne, increasing my infill/wall overlap, changing my infill direction, and changing my flow ratio to 1.1 to help fill in the tiny holes.
None of those changes seemed to make a huge difference on my 0.4mm nozzle (which i’m hoping to use for these since the extra print time on 0.2 is just so insane haha) so i’m wondering if there’s anything else I can try?
Any thoughts, or being pointed in the right direction would be appreciated! Thanks!
Given what you already tried, I think I would experiment a little with K values as well. I’m not sure that could be it, but it’s easy enough to try it out (eg. if calibrated to 0.020, try 0.010 and 0.030). Please keep us updated!
Oh, and another suggestion; Since many of your pixels are free from gaps, I would watch the slicer preview very carefully (zoomed in, and moving the sliders a G-code line at a time) on a good one and on a bad one, and try to understand the difference.
Just wanted to chime in here for anyone still dealing with these holes. The above suggestions are great but one thing that will most definitely help is adjusting the “Slice gap closing radius” and resolution. SGCR will tell the slicer to fill gaps that are smaller than the setting youve chosen. Larger number = more gaps closed but could also mean some specific small details are lost.
Resolution will make details sharper theoretically. You’ll notice a large number will square off curved lines and give you muddy/blocky small details (which might be good for OP as theyre printing pixel art)
Something else to note is arc fitting which converts curved lines into a series of turns that reduce the amount of g-code items sent to the printer
