Any way for pause in the layer?
I need to make a print with tpe so because of that I can not use the ams. I need to make support in it but i can only set a pause at specific layer height and not between. If I slice it with the interface support as pla it ignore the change. It’s a really simple print and its for a customer. Need help! (I’ve already tried to print the support separate and then pause before seal all toghether but i need to print 50 object and not all the time go well. Its not stick to the plate and fell off. 20/100 success rate)
It’s not really clear to me what you are trying to do and why a "pause at a layer height won’t work. Perhaps some pictures would really help explain it.
You can edit in gcode using this method but be careful as you need to understand what you are doing.
After you slice a model you can right-click the layer bar and insert a manual pause.
If you want to pause midway through a layer rather than the start of a new layer, you will need to edit the GCODE as @JonRaymond has already said.
However, if you are using PLA (or any other material) for support you will swap between the two materials throughout the print.
Even for a simple print, this will be very time-consuming.
Do you have a screenshot of the model to assist us in understanding how complicated?
It may not be easy to update the GCODE to achieve your needs.
I also attach the gcode file. From what i can understand i need to put an m600 after the “m204 s10000” (first pictures) so before the print change layer line it will pause and i can change the filament. Also i need to put an m600 after the “m204 5000” (2 pictures).
Sorry for my english. I’m tring to not use the translator
First of all thank you all for the replays. I attacht some pictures.
In the first i need to change filament from tpe to pla at the start of the layer but if i do with right click and add pause or normally make pla as interface layer it dont work. It keep printing with tpe. So at the beginning need to change from tpe to pla and in the second i need to return to tpe before finishing the layer.
