Anybody that brought the maker kit essential a can you post a picture of what it looks like.
I want to know before I buy it
Update: sorry I figured it out.
Apparently there is pictures on the Bambu store.
- M5x12 SHCS Machine Screw (5PCS) -AA001
- M3x23 SHCS Machine Screw (10PCS) -AA003
- BT2.6x8 SHCS Self Tapping Screw (20PCS) - AA004
- M2.5x10 SHCS Machine Screw (20PCS) - AA005
- M2x10 FHCS Machine Screw (20PCS) - AA007
- M2x6 FHCS Machine Screw (20PCS) - AA009
- M2x8 FHCS Machine Screw (20PCS) - AA011
- M2.5x6 BHCS Machine Screw (20PCS) - AA013
- M2x12 FHCS Machine Screw (20PCS) - AA015
- M2x14 FHCS Machine Screw (20PCS) - AA017
- BT2x8 SHCS Self Tapping Screw (20PCS) - AA019
- M2.5 Stainless Steel Hex Nut (20PCS) - AB001
- M2.5x5x0.5 Stainless Steel Flat Washer (100PCS) - AC001
- 0.6x12x70 mm Helical Compression Spring (5PCS) - BB001
- 0.3x6x80 mm Helical Compression Spring (5PCS) - BB002
- 0.3x3x10 mm Helical Compression Spring (20PCS) - BB003
- 0.5x5x25 mm Helical Compression Spring (5PCS) - BB004
- 0.5x7x12 mm Helical Compression Spring (10PCS) - BB005
- 1x5x3 mm 120 Degree Torsion Spring (5PCS) - BC001
- 0.4x4x6 mm 120 Degree Torsion Spring (10PCS) - BC002
- 4x2 mm Round Magnet (20PCS) - CA001
- 2x18 mm Stainless Steel Dowel Pin (20PCS) - DA001
- 2x25 mm Stainless Steel Dowel Pin (20PCS) - DA002
- 2x14 mm Stainless Steel Dowel Pin (20PCS) - DA003
- 2x13 mm Brass Dowel Pin (20PCS) - DA004
- 2x22 mm Brass Dowel Pin (20PCS) - DA005
- 2x33 mm Brass Dowel Pin (10PCS) - DA006
- 6003 Plastic Deep Groove Ball Bearings (1PCS) - EA001
- 6204 Plastic Deep Groove Ball Bearings (1PCS) - EA002
- MR52 Steel Deep Groove Ball Bearings (6PCS) - EA003
- MR128 Steel Deep Groove Ball Bearings (6PCS) - EA004
- 6704 Steel Deep Groove Ball Bearings (1PCS) - EA005
- F8-14M Miniature Plane Thrust Ball Bearing (1PCS) - EB001
- 6mm Stainless Steel Balls (10PCS) - FA001
- USB Speed Controller-Compatible with TT motor (1PCS) - IA002
- AA Battery Case with PH2.0 Connector (1PCS) - IA003
- AAA Battery Case with PH2.0 Connector (1PCS) - IA004
- Power Distribution Board (PDB) - 4 Channels (1PCS) - IA005
- Self-Locking Button Switch with SH1.0 Connector (2PCS) - IA006
- Potentiometer Board with SH1.0 Connector (2PCS) - IA007
- AAA Battery Spring Contact Plate with PH2.0 Connector (1PCS) - IA008
- USB-A Power Cable with PH2.0 Connector (1PCS) - IC001
- 100mm Wire Pair with SH1.0 (5PCS) - IC004
- 50mm Wire Pair with SH1.0 (5PCS) - IC005
- Jumper Cable with SH1.0 Connector (5PCS) - IC006
- 200mm Wire Pair with SH1.0 (5PCS) - IC007
- 100mm Wire Pair with PH2.0 (2PCS) - IC008
- 4 White 3030-LED Board with SH1.0 Connector 5V (2PCS) - KB001
- 1 White 3030-LED Board with SH1.0 Connector 5V (2PCS) - KB002
- TT Motor (DC5V 59RPM CCW Single Axis) 1PCS - LA001
- N20 Reduction Gear Motor 150rpm (1PCS) - LA002
- N20 Reduction Gear Motor 400rpm (1PCS) - LA003
- N20 Reduction Gear Motor 1000rpm (1PCS) - LA004
- N20 M3x25 Threaded Shaft Reduction Gear Motor 400rpm (1PCS) - LA005
- N20 M3x45 Threaded Shaft Reduction Gear Motor 1000rpm (1PCS) - LA006
- N20 M3x60 Threaded Shaft Reduction Gear Motor 1000rpm (1PCS) - LA007
- N20 Single Shaft Worm Gear Motor 25rpm (1PCS) - LA008
- N20 Dual Shaft Worm Gear Motor 130rpm (1PCS) - LA009
- 9g Servo Motor with Clutch Protection (1PCS) - PG001
- 14mm Plastic ball (10PCS) - ZB001
Oh it’s just stuff I mostly have.
Thanks though at least I won’t spend a thousand points on it.
Rowen,
You can see pictures of what’s in all the kits in the points store (except the tank and the castle) by pulling it up in the Makerworld Store:
Oh I’ve been looking at the thumbnail in maker world but didn’t look at the store ![]()
interestingly i was just looking at this recently as i’ve already got every PLA/PETG and needed something to use my points on
The Maker’s Essential Kit A is a bargain already, but with points it’s even cheaper!
In AUD
- the Kit is $307
- Bought separately the parts would cost $414
- Purchased with points (99% off coupon) it costs $3 and 1219 points
- 1219 points equals roughly $155
It’s a massive kit with a bunch of motors, wires, springs, LEDs etc and is an absolute bargain if purchased with points
Here’s my sheet I’ve started using to keep track of my stocks, the maker kit tab has some data but isn’t fully formatted yet
Why not just get another printer?
i have 5 XD
Oh wow, which ones? Did you pay for all of them with bambu gift cards?
I found Waldo (Wally for the Brits).
Two of them, do I get a prize?
And us, people from Spain.
I purchased a p1p when it was released, as well as an a1 mini
I got 3 more a1 minis with gift cards (one is still in a box as a backup if another fails
I’m not trying to brag, I’m not even close to the numbers of some of the other creators around here
But having all the colors and parts keeps me happy
Is this printed or custom from a lego store? Looks very cool.
Custom from the Lego store in Sydney. Not sure if many others do it but no other ones in Australia do
