Anyone Else Noticed Slower Printing Speeds?
Has anyone else noticed the slower printing speeds on their A1? I have the latest Bambu slicer, A1 and AMS firmware. I loaded one of my models I designed to print which should take about 3Hr50 and I am now quoted over 7h with no change to the print settings.
This is the model on Makerworld, note it should only take about 4h on a P1S to print 4 plates: Cotton Bud Storage Dispenser with Rotatable Lid by BertBee - MakerWorld
What has changed in the GCode or Firmware to almost double printing times?
If you print them individually, it will take less time, because you have 123 filament changes when it is done your way.
It takes 4h29minutes on my A1 if I use separate plates.
Thanks for checking mate, I honestly cannot remember it taking that long in the past when I printed it all on one plate. I accept however though the findings in that it is meant to take that long based on both our machines slicing it whilst estimating the same amount of print time.
You can also print by object on one plate which will reduce the color changes to minimal. You’ll need to turn that on then spread them out.
I just created a print profile, but I cant upload it here:
4 hours on an A1
The .3mf is 28,5 MB so it sadly exceeds 520 MB.
Brilliant, thanks guys much appreciated
yes I have as well. With just one color is takes significantly longer
