Anyone else running into this eSun issue?
I have 2 spools of PLA Pro that were recently purchased and both have the same problems. They were both bought within the last 5 weeks The spools were different colors. Once about 40% to 60% of the spool is used the filament starts jamming because the windings along the side are buried 2 to 3 levels below the outer winding on the spool. And it got worse the more filament I used.
I bought one spool from Amazon, and it was new enough I was able to send it back and get a refund. The jam happened 3 times and caused the prints to fail, wasting the filament already used.
Pulling on the filament that jammed last night by hand, it is very difficult to unwind because of the winding problem I described. You should see the kinks in it. I have a used spool with no filament, so I’m going to have to wind the remaining filament onto the used spool as even my sloppy hand winding is better than the machine winding.
I’ve had no problems with any other brand of filament, just eSun. And I use their filament because I’ve never had a problem with it in 4 years. I have a spool of white PLA + that is over a year old and it has no problems with the filament winding and I’ve used almost 80% of it. So this appears to be a recent issue. I finished 2 other eSun spools I had with no issues on my P1S.
The jamming is not only ruining the prints but I’m worried it may lead to extruder issues from clogging it with ground pieces of filament.
Since I’ve never had issues with eSun, I was curious if anyone else has recently purchased filaments that did this.
Did send an email to their tech support suggesting they look into this.
Yes! I’ve had the same problem with eSun. Poorly wound about every 10th or so spool I used. Bad enough that I switched vendors. No problem since.
Good, so it’s not just me. So far the Voxelabs PLA Pro (from Flashforge, different than VoxelPLA), has been wonderful. Works just as good as the Bambu Basic. It runs perfect using the BambuLab PLA Tough preset. Just not as many color choices. Their ABS has worked well, just a problem with drooping when bridging, but to be fair, I haven’t run a temperature tower test or flow calibration on it yet. Nice thing was no warpage on a 7 inch long object.
Now that I got my reusable spool issues straightened out, I can start using the BL PLA basic refills I have. That gives me way more color choices.
I never had problems with windings from esun PLA+. But i did have problems with filament breaking in the extruder. Went to polymaker and problems gone.
Yes! I’ve had the same problem. I ordered a new roll and it had the same problem. PLA+.
Year is 2024 and this is still happening.
I have recently started on my 3D printing journey and using eSUN PLA+ filaments. When it gets to below 50% it randomly jams. I just need to rotate the spool a little which fixes the issue but it is super annoying that I have to clear the messages on the printer and push the filament to extrude.
I guess I need to find a different vendor.
December 2024 and this problem is happening to me at this moment with my black esun spool That is just about halfway used up
I’ve had this happen on at least 4 eSUN PLA+ spools in the last couple of weeks, and when it does my X1 Carbon fails to notice the jam and keeps on printing air thus ruining the print. Shouldn’t the filament run-out sensor notice this? Since cardboard spools are not recommended for use in the AMS I run them externally.
Me too! My A1 keeps printing in midair and later i found out it was because of my eSUN filament stuck in the hottend. It took 1 hour to pull it out.
I have the same issue. Kind of suspicious that the issues I see with eSun on here and on Reddit are the exact same as the Bambu spools. Seems PLA, PLA+, are not gwtting the QC they need to. Sunlu is also an issue with this. I have no issues yet with the other brands that I use.
Well, here we are in 2025 and it looks like not much has changed with eSun. Still poorly wound
i just cam on here to look for this, i have just had some esun jam so much that i abandoned the print and changed filamet to a different brand, i will rewind this one when i have built a winder lol, fo now its getting vac packed, i hate to waste, even if its just half a reel lol!
I get this issue on almost every spool of Esun PLA-SS / PLA-HS in the AMS.
I bought a lot of it in bulk to get cheap prices so I’m stuck using it for now.
I find that the problem gets worse the closer it is to the centre of the spool. I’m able to print 600g and then I switch it to another printer which doesn’t use AMS.
BUT I’d love to load these up in the AMS and use it without the faff.
I suspect when the filament amount is low, the angle the AMS tries to pull the filament is too steep and also the weight of the spool is less so it pulls it up and jams it against the lid. I am trialing using a stiff piece of PTFE tube to angle the filament higher. Seems to be working well so far.
I use older filaments in my AMS and use the rims designed by @AU3D.
I have gone through 20+ eSun cardboard spools from start to finish with no issues.
https://makerworld.com/en/collections/565167-cardboard-spool-adapter-ring
I’m having the same issue. i absolutely despise eSun PLA+ filaments on the cardboard spools. This PoS is CONSTANTLY tangled, around 2/3 of the spool and there’s NO WAY to print anything bigger without checking every 10-15 mins.
Just before the current eSun spool, i went through gold silk PLA from Creality and there was NO SINGLE ISSUE. I was able to print 6-8 hours long models without a single error.
eSun is absolute trash and this is definitely my last spool from them for a long time. There are many other producers to check fortunately.
i fix the problem with coloer changing you need to cut the tip with a 45o angle
This filament winding issue seems to be affecting multiple eSun PLA Pro spools recently. When filament layers are buried too deep under outer windings, it often causes jams and print failures. It’s important for anyone using eSun PLA Pro to check the spool before printing large parts to avoid wasting material and risking extruder damage.
Was starting to go crazy. Literally every roll of eSun I’ve used has done this. Even when its fresh out of the box. I’ve run dozens of rolls from other brands through and never once encountered this.
