Anyone notice support bed adhesion issues since Studio 2.0 update?
I have several prints that never had any adhesion issues with studio 1.x but their tree supports keep failing to reliably adhere to the bed with studio 2.x
has anyone else noticed this?
edit: and yes my plates are cleaned, has happend on fresh washed plates. filament is dry.
had exactly the same issue. I’ve gone back to the old version or use handy app where all still works fine. hopefully this will be remedied soon
i wonder if it is the hybrid tree supports (default in 2.x), I just tested forcing Organic (the default in 1.x) and didn’t have any detach
I have had the same adhesion issues and print failure with X1C and P1P since the 2.x version. This happens on old files that I printed multiple times perfectly in the past.
How can I downgrade to the last software version before 2.x?
I think if you check (i have an A1) the bed temps were turned way down as the defaults. If someone can confirm that, we may have found the problem.
the satndard bed temp was around 60c, then at the 2.0 update, i notice around 45c.
I thought I had posted but apparently not
switching my supports to “tree, organic” instead of “tree, default” (default is hybrid) solved it for me.
