Is there any way to make the top layer settings apply to all top surfaces in either Bambu Studio or Orca Slicer? I really like the single wall top surface looks but it only applies to the last layer and not all top surfaces.
As far as I know it’s a problem with “Arachne” wall generator. If you switch to “Classic” it is like expected, at lest in the current Bambu Studio beta.
Wow, thank you! Using the “Classic” wall generator does indeed put a single a single outer wall on all top surfaces. There are several other bug threads on the Prusa/Softfever forums about this. Apparently it is not an easy fix for the Arachne engine.
Real bummer as I typically use a 0.6mm nozzle with Arachne and get excellent results. I guess I’ll have to decided on a case by case basis which generator to use.
