Thank you so much for posting the video. However, I have to agree with what has already been said here. Using only the seconds as a reference of an edited video that isn’t even in real time really made me laugh out loud. It’s a really weak argument.
Even comparing a two-nozzle system with a single-nozzle system is questionable because the range of required functions introduces complexity. You should compare a single-nozzle system with a single-nozzle system, or a two-nozzle system with a two-nozzle system.
Besides, how does that actually relate to the main topic? Why should a two-nozzle system be considered less reliable than a single-nozzle system across the board? Because it has duplicate components?
Just to play this very far-fetched comparison: Is a motorcycle more reliable because it has two tires, compared to a car with four tires?
And now, to go back and connect the dots on how this side discussion got started:
Neither the P1S nor the P2S had a plug-in system for the extruder. That’s simply a false statement. Both screws and cables had to be removed. The cables from the hot end had to be disconnected to access the screws on the extruder.
