My SD card that came with the printer failed and I was able to replace it with a new one, but I no longer have all the files that were on it. I don’t remember if there was anything on there I should have kept. Is there somewhere I can download the original SD card files? I do remember there being a couple project files that were nice to have like the spool and a tool to line up plate texture sheets.
Yup Bambu has them on the wiki.
https://wiki.bambulab.com/en/general/bbl-printer-internal-sliced-files
They are in the knowledge sharing section of the wiki.
Scroll down, look for links to stl files.
Thank You so much. So all that was on there was the project files (.stl) ? That’s kind of what I figured, but wanted to be sure. Thanks again.
I see the links to the stls are there, but is there a way to download the already pre sliced files?
Yes, check my link above. The sliced files are there as well.
I recently had the sd card in my A1 go corrupt. I replaced it, and am looking to see if i can find the files that came on the original. I see bambu has the links to the stl’s but im looking for the already pre-sliced files, specifically the benchy and the scraper.
Scroll down to the A1 & A1 mini sections.
The direct link to the file A1 ZIP
https://public-cdn.bblmw.com/wiki/model/A1-internal-sliced-files.zip
The direct link to the file A1 mini ZIP.
https://public-cdn.bblmw.com/wiki/model/A1-mini-internal-sliced-files.zip
MakerWorld test model links
A1
https://makerworld.com/en/collections/138903-bambu-lab-a1-test-models
A1 mini
https://makerworld.com/en/collections/12780-bambu-lab-a1-mini-test-models
my p1s card had a file i could not delete so i was dum and formatted the whole sd card and i cannot print stuff now with out the other files not the gcodes or the stls
There is nothing on the SD card that is needed to be able to print. Did you format via the printer display or your computer? It needs to be formated FAT32. If you were unable to delete a file it may be a sign that your card may be failing.
i printed something and everything is back
