Hello, I don’t think the sounds are normal how can I fix that? Probably something with the z belt. It’s only when I move the bed down.
this sound is not normal. I do not have such a noise moving the bed down.
with best Regards
Peter
Are the lead screws clean?
Have they been cleaned and greased again? This might help some until support can get back with you with a solution. It would be nice to grease the bearings but they are shielded for contamination.
The Z rod is gripping the heatbed cable protection slieve. Try to reroute it.
They are clean and greased, it sounds like there is filament stuck or something… but I can’t find anything
I’ve also put a little grease on the bottom z belt but nothing got better ![]()
