Artifact after color painting in Studio
Studio bug
This is a screenshot of layer 16 out of 19 total. The 4 green lines appear after I color paint the brown surface in Studio. Without painting, the surface is uniform straight lines. The 3 green lines across the top aren’t a problem because they get covered up. The green line by itself is a problem because it ends up being visible in the final print. I’ve checked the model and it’s completely solid. Plus these artifacts appear only when I color paint.
Is this a bug? Does anyone know how to get rid of these lines?
It looks like you may be encountering a rendering artifact or glitch in your software. Ensure that your graphics drivers are up to date. Sometimes, rendering glitches can be caused by outdated or incompatible drivers.
I’m having the same issue. A random area of color in between layers
Have you been able to resolve it? Mine will go away if i scale the print down to 90%. But if I scale it up, they increase.
I never got it to work. Seems like it’s a bug in Studio. I ended up changing my model to print parts separately in different colors instead of using the AMS.
