Fillets are a known issue in this respect. You can attempt to combat it with smaller layer height in that area (or variable layer height), and or slower overhang speeds. Also, make sure you are starting with dry filament, PLA isn’t usually an issue but it can be in certain instances iirc.
I believe the best way is to handle it in the design. Chamfers down to ~30 - 40 degrees will print well, some suggest chamfer followed by fillet, it’s all about the start of it, for a fillet the starting angle is going to start very small requiring more overhang to accomplish the curve, then it eases out.
You could also use support, I am guessing that the auto is not doing anything so you could switch to manual and paint it on.
