Problem
When filament stops feeding mid-print (clog, tangle, extruder slip), the printer continues “air-printing”. By the time you notice, the nozzle is centimeters above the part and hours of printing are wasted. Resuming is theoretically possible, but manually finding the exact failed layer with calipers and editing G-code is tedious, imprecise, and out of reach for most users.
Proposed Solution: “Crash-Resilient Recovery”
An opt-in feature in Bambu Studio / firmware allowing the printer to automatically locate the last solid layer using the built-in toolhead force sensor and cleanly resume printing.
Core Architecture & Failsafes
1. Safe Coordinate Recovery (homing upwards):
- After clearing a clog or changing a nozzle, toolhead coordinates may be lost.
- Instead of risking a collision by homing down to the bed, the printer could re-establish Z by homing upwards, to the top of Z travel. This could be implemented, for example, as sensorless homing to Z-max with motor stall detection, similar to Prusa MK3/MK4. I don’t know if the A1 / A1 mini drivers and frame support this as-is, so this is a suggestion for Bambu engineers to evaluate.
- This would establish the absolute Z reference without ever bringing the nozzle or X-axis gantry close to the model.
2. Slicer-Assisted Probing (“Resilient Mode” Workflow):
- Similar to how Timelapse mode alters toolpaths to add prime towers and park moves, an opt-in Resilient Print Mode allows the slicer to:
- Generate flat sacrificial probing pads within infill/support structures every N layers, or identify guaranteed solid flat perimeters.
- Maintain all horizontal travel strictly above the model’s highest bounding-box peak.
- Eliminate the risk of probing thin curved walls or sparse gyroid voids.
3. Gentle Contact Sensing via Existing Strain Gauge:
- The A1 toolhead load cell descends slowly from a safe clearance height with a sensitive force threshold (far lower than bed leveling force).
- If clearance to the purge wiper is obstructed by the model, the printer simply prompts the user: “Please clean the nozzle tip manually with a brass brush before probing.”
4. Material Consistency via RFID Ecosystem:
- To eliminate variables like material flex and elasticity, Bambu Lab could restrict this feature to official Bambu RFID filaments with pre-calibrated stiffness profiles.
5. Edge Cases:
- Under-extruded / spongy layers just before the failure: handled by the slicer’s probe pads, a sharp probe pin, or an additional camera (AI) check of the top surface.
- Cold seam between old and new layers: the first resumed layer is printed hotter and slower to restore layer adhesion.
Why Bambu Lab Should Build This
- Little or no extra hardware: The force sensor is already built into the A1 / A1 mini; the rest is slicer and firmware work.
- Massive user value: Saves 500g+ of wasted plastic and 10+ hours on failed long prints.
- Competitive edge: Turns a traditionally frustrating, “hacker-only” G-code recovery into a seamless, consumer-friendly Bambu experience.
…and there’s a good reason why they don’t integrate it.
…and specifically, what you’re describing simply isn’t feasible as things stand.
Even professionals usually wouldn’t touch what you’re describing. Better to waste a few hours than risk damaging the printer. Bambu will never integrate something like that - they always play safe.
It’s a nice idea in theory, though.
I appreciate the cautious perspective — protecting the printer hardware is always the top priority. However, saying this “isn’t feasible” underestimates what the Bambu engineering team could achieve with their own hardware.
Here is why this is well within the realm of feasibility if implemented natively by Bambu Lab:
The load sensor is already designed for delicate contact:
The strain gauge / load cell in the A1 toolhead triggers at minimal force during bed leveling. Probing a flat printed plastic surface at a controlled, slow probing speed exerts no more mechanical stress than probing against a rigid textured steel sheet.
Native firmware vs. 3rd-party hacks:
Third-party tools and manual G-code edits are risky because they lack real-time sensor integration. Bambu engineers, however, have direct access to low-level telemetry: load-cell thresholds, motor stall guard, and precise step counts. They can set strict safety envelopes (e.g., abort immediately if resistance is met above an expected threshold, or if readings are inconsistent).
The Slicer knows the geometry (Top-Down Safe Probing):
The printer wouldn’t be probing blindly. Because the slicer knows the complete 3D mesh and maximum height envelope, it can orchestrate a failsafe routine:
- All horizontal (XY) travel moves happen above the model’s highest possible point (clearing any printed geometry).
- To safeguard against user error, negligence, or prints that air-printed for hours, the nozzle can start probing downward from the highest safe Z-level, gradually descending to find where the solid model actually begins.
- It targets predetermined flat solid areas rather than delicate perimeters or infill voids.
This completely eliminates the risk of the toolhead crashing laterally into the part.
Bambu Lab’s core identity is automating “risky” manual tasks:
Things like automatic resonance testing, dynamic flow rate calibration, and active vibration compensation used to be considered “only for experienced tinkerers” before Bambu made them seamless and consumer-ready. Automating failed-print recovery with built-in sensors is the logical next step.
Even if launched as an “Experimental” feature with clear warnings and a confirmation prompt (“Detected surface at Z = X mm. Verify before resuming”), it would save countless kilograms of wasted filament and hours of print time without risking the machine.
Exactly, because the hardware simply isn’t designed for this, and that’s not something you can fix with firmware or software. Even if ChatGPT tells you otherwise.
- How is the printer supposed to determine which points need to be detected?
- What about different materials? PLA and TPU? They deform differently.
- What about mixed materials?
- What about material shrinkage?
- How is the printer supposed to accurately track the exact point where the print was interrupted, even down to the specific step between layers?
- What about the prime tower?
- Should supports be included too, even though they break off so easily?
The hardware simply isn’t designed to handle these kinds of calculations, no matter what ChatGPT tells you.
Like I said, it’s a nice idea, but by now you’ve somehow spammed it across all sorts of different topics, and it makes you sound more like a bot… Please don’t take this personally, but it all sounds like marketing buzzwords rather than practical experience.
Of course, you’re free to wish for whatever you like, that’s no problem at all. That’s what the forum is for, after all.
But even then, I’d say that if you really want to pursue this, you should get in touch with the developers directly via GitHub.
Alternatively, get in touch with the OrcaSlicer team and ask them what they think about it.
The machine in front of you is rather dumb, it reads gcode line by line and does what it’s told, over and over until you have a benchy and its done. You are very strongly overestimating the firmwares capabilities for even a simple thing like recalculating routes on the fly etc… especially on the older end of the bambu fleet.
