Auto supports created with space between
This is my first ever attempt at slicing something to print - so Im probably doing something wrong, but my auto tree supports often seem to be created with space between the support and the object. (which obviously seems wrong).
Am I doing something wrong or is this just an error in the algorithm?
(edit: it seems to be really only when I check 'support critical regions only)
thanks for any help!
Id quite like to try critical regions only to see how well it does as it would reduce cleanup, but might just have to try with that unchecked I guess.
Bonjour, c’estnormal. Il doit y avoir un espaceentre le support et la pièce. Cela permet de pouvoir ensuite enlever kes supports. Si ils etaient collés à la pièce, il faudrait les couper avec un outil et ensuite limer ou passer du papier abrasif.
