Autodesk Fusion 3MF and/or Bambu Lab Studio plug in
Will there ever be a Autodesk fusion Bambu Lab Studio plugin or a compatible 3MF or able to import straight into BLS straight from Fusion?
I use the 3d print option in fusion to send single body stl’s to bambu studio directly. You just have to setup the 3d print > print utility - custom then under application select bambu studio executable.
I had not tried it, but it is still only the 3d geometry right? Similar to exporting the mesh and opening from bambu studio.
Yes it is (have to type 20 characters to post msg, stupid rule)
Yeah, I am hoping for something better eventually… BLS uses 3MF so I am hoping we are close…
