I have found that the new(ish) feature that adds support for the A1 mini when that was not the original target printer, but, the print envelope is small enough - fails when ‘print-by-object’ is set on the plate.
How to reproduce
- Set the target printer to P1S (could be any non-A1 mini printer)
- Set the plate option for print order to - 'print by object"
- Auto-arrange the objects
- Save the profile
- Upload the profile to MW
The A1 mini is NOT found in the supported printers list.
Assuming this might be a layout issue, I tried this…
- Set the target printer to A1 mini
- Set the target printers to P1S (could be any non-A1 mini printer)
- Save the profile
The A1 mini is STILL NOT found in the supported printers list.
It doesn’t appear that any arrangement, number, or height of objects fixes the problem.
I even tested the issue with a single object, but it failed.
From my testing, it appears as simple as…
If you set the print order to by-object and target any printer other than the A1 mini, your profile will not be compatible with the A1 mini no matter what other choices you set.
The only resolution is to target the A1 mini to start with and have the print durations all appear significantly longer than they would have had the profile target the P or X series.
Uploading two print profiles (one targeting All printers and one targeting just the A1) as a workaround sets up future issues that should be avoided.
