I have received my P1S for xmas, and I’m amazed with how quick and clean it prints.
I’m coming from Ender S1 / Klipper, (so not a newby) - so it is a big jump in terms of speed and quality of the prints.
However I’m struggling with layer adhesion → overall print strength. I have print couple of things already and when there is a model with thin walls that are rising from a flat surface (similar to “L” figure), prints break in hand.
(Model used: ESUN Bambu Lab AMS Cardboard Spool Adapter Ring by DesignCraft - MakerWorld and printed wide model)
I went back to my Ender/Klipper setup (volumetric speed around 6-7mm3/s) and you almost cannot break it by hand (if you try to break the vertical wall from the base of that profile → basically trying to break the “L” figure, where the both lines connect).
Some parameters using on Ender print
- Vol speed - around 6-7 mm3/s
- Layer height: 0.2
- Line Width: 0.4
- 3 walls
- 4 top/bottom layers
- 20% cubic infill
- Max speed: 60 for outer and inner walls
- Infill speed 130
- Filament: Sunlu PLA+
- Filament temp 205
- Bed temp 60
What i have tried so far on bambu:
- Using Bamboo filament (new spool), with standard 0.2
- Using Sunlu PLA+ filament with eSun PLA+ profile, standard 0.2
- Using Generic PLA profile, standard 0.2
- Slowing to volumetric speed of 12
- Turning off all fans (except part cooling)
- Printing with open or closed doors
- Dumping nozzle temp to 230 from default (220 Esun PLA+ profile)
Best result i got: when i slowed down to vol speed of 6mm3/s. It is much stronger, but still not the same as Ender (Ender bends more before breaks, Bambu is stiffer and breaks sooner) it is like 90% of Ender strength.
I know that I can increase infill and wall number would help, but that is not the point (for now). Especially as using org Bambu PLA filament and Bambu profile does not make it better.
I’m trying to understand what is the real cause of it. Is it filament or hotend limit? Why a better/more advanced printer cannot produce the same strength as Ender.
I understand that speedy printing produces less strength, but I would never expect how much (in my case).
Am I missing something obvious when trying to print PLA+ at least with Generic profile with vol speed of 17 mm3/s ?
