Background: I have 5 P1S Printers. 4 out of the 5 print great, no issues (using Fast PLA, same on all). The 5th printer (the newest I bought), started giving me grief. The top surface has voids in it (as if no filament fed) and feels chalky, the other 4 printers give me a smooth shiny surface. This is with ironing on. Without ironing, no chalky feel but I get a lot of pitting. I’ve attached pictures of a good print (same on 4 printers) and bad print. The firmware is the same, the file is the same, and the settings are the same. My guess was that the filament isn’t quite feeding properly or being obstructed somehow, but that’s just a guess. This is what I’ve tried so far:
- Re-sent the file
- Degraded the Firmware
- Re-loaded the Firmware
- Changed filament
- Changed the position of the filament in the AMS
- Calibrated and set pressure advance (several times and tried several settings)
- Installed a new nozzle
- Installed a new Extruder (stainless steel)
- Changed ALL the PTFE tubes
- Changed the Tool Head cover (with the fan)
- Printed faster, printed slower
- Cleaned the carbon fiber rods
- Cleaned and greased the z-axis rods and all stainless rods (z and y axis)
- Tightened the belts (several times)
Some observations.
- Watching the print I can’t visually see anything happening (no jerking, shaking, or ‘strange’ sounds, etc.)
- After changing the PTFE tubes, it got a ‘little’ better. The voids were less but the surface still felt chalky.
- I did find a short black screw in the bottom of the printer that I swear wasn’t there before. Tried looking for a place if could have come from, but there must be a hundred of them and can’t find any ‘empty’ place it might have come from.
Before I put in a ticket, I thought I’d reach out to see if anyone else has had this issue or has any suggestions I could try. Any help or suggestions would be greatly appreciated!
Bad Print:
Good Print:
Hard to get my phone to focus so close, but I think it shows enough to get the idea.
